69_340_GTS
Just 2 mufflers total. One on each side. My '01 Mustang was like that. They used an H-pipe too.
Can you just slip fit them into the end of the pipe? Just for a sound test? I think you’ll have enough room to just stuff it on for a sound test. Maybe not so much driving with them in though... LOL!
Those are all way too long. I don't have a straight piece of exhaust tubing underneath the car that is long enough for even the shortest Powerstick. I think my longest straight before the muffler is 18". Anything before and after that is bendy. Although, they said you can add resonators in the back to help with drone (See attachment - last 3 words of big paragraph).
Again, what you need is a helmholtz. The only straight section needed is for an easy attachment pipe. They can be perpendicular, you can bend them to run parallel to whatever wackiness you have under there, it can even be a non-tubular chamber (although the math may change a bit).
No more drone!
The above link addresses specifically the issue you describe.
That's my car above in #33. Resonators went behind gas tank and tucked up, you can't even see them from behind. If you do see them it looks like back of gas tank. I went from Flowmasters to Magnaflow, better sound but still had drone at different rpm. Local shop dealt with it and did great job! Great sound, no drone, love it![]()
I still think you need to lop off the turndowns and stick the exhaust about 1/2" past the bumper first.
I have the same system (but with long tubes), and it droned/drummed under the car like crazy with the turndowns. I went with some stainless tips that stick out past the bumper and it helped a lot. The car is actually pretty quiet inside with the ultra-flos
