Stop in for a cup of coffee
Yep, bubble flare. Tried all evening, autozone has no line with a double bubble flare, gonna try the orielly near work in another zipcode tomorrow
Bubble flare. No such thing as double bubble. Unless you are asking for chewing gum. Ask to see the metric brake line. Theres 2 styles.
Since when does jeep use bubble flare?
Gm used it a little, but most domestic use inverted flare.
It's inverted at frame where the rubber hose connects, but up top at the ABS distribution block, it's a bubble flare and metric threaded
Adapter from inverted flare to bubble flare. So chris can fix his heep.
Trying to figure out when to get to your house, Keefer is coming up next weekend so that's out and hops will be starting the end of the month if I am up to it.
