Mopar92
According to what I’ve read I need a 32 tooth for my 833 Duster. 27” tires and a 3.23 gear.
According to what I’ve read I need a 32 tooth for my 833 Duster. 27” tires and a 3.23 gear. Anybody have a nice on to part with? Thanks.
able to compare actual speed to what your speedo is showing you now
The 28" tall rear tires, 3.73 rear end gears equal a 35 tooth driven gear. At freeway speed, the 35 tooth gear spins the speedo 1.21 times too fast compared to my smartphone app for speed etc. I did the math, and choose to be closest tooth count (43) for freeway speed on my speedo, as it has a smaller error at 25 mph ( 1.16) & a larger error at higher speeds. The slope of the speedometer error is at a different angle than that of the slope of the actual speed. They are not parallel in my car.
I reread your post and now I'm confused, what are you running right now? and what is your speedometer speed and your GPS speed with that gear?
Here in Colorado the speed on the interstate is 75 MPH most people do 80 to 85. Was in CA last fall, and in the immortal words of Sammy Hagar "I can't Drive 55"moving in slow motion when you're only doing about 35?
Police cars had calibrated speedos. Very few other cars did.
It isn't the gear's fault, your speedometer itself is not working properly.Sorry. It made sense in my mind, but that's how legends are made.
I called Jamie Passon, and gave him my numbers for tire diameter and gear ratio. He confirmed that I should use a 35 tooth. The same number I come up with on all the charts. Well, some charts don't show the numbers for 3.73 gears.
I ordered a 35 tooth gear from him, and when I was installing it, I found that I had a 35 tooth gear in there already. It looked a tad worn, so I put the new one in. My current speedometer error remained.
Using GPS on my Android phone to check actual speed, I found that my speedo read 29 mph at 25 actual mph, at 70 mph indicated I was at 57 actual mph, at 80 mph indicated I was at 65 mph, at 120 indicated I was at 95 actual. The ratio of error increases as the speed increases.
If I plotted both sets of these numbers on a graph with MPH on both sides of the chart, the actual MPH would split the chart evenly in half right down the middle. Now, when I plot my indicated numbers on the same chart, my indicated speed line would start at the same place on the chart at "0" MPH at the lower left corner and be just above the actual line getting farther and farther away from the line as speed increased. The lines have different slopes and diverge from each other at a certain ratio that I forgot how to calculate from my algebra classes. A picture would work better to explain it, but I don't know how to make one on this PC.
I haven't put the new gear in yet to see what happened, as I had other priorities this weekend...
The speedo gear holder at the transmission is indexed. It must be turned to one of four (?) positions dependent plastic speedo gear. I haven’t checked the book on this for a while, so look into the FSM for details.I have a question... I saw a post where someone had numerous gears for sale and the 40+ tooth gear seemed twice the diameter as the 28-30 tooth gears. if the center-line of the gear is the same for each gear how can the lower number of teeth gear fit into the trans and mate to the output shaft gear or visa versa? is there a unique insert that is needed for certain gears?
