dubree 61
73 swinger
My 8 3\4 rear housing cut down
Do you think them heads will work OK on my 360 I know they have been ported and polished by Mopar I'm running headers and a four barrel carb I'm pretty sure its a 600 edelbrockNice. Those will make for some high compression on a 360.
The motor I'm putting these on has a small can the guy who built the motor kept asking what kind of carb and intake I was going to run he said he would tell the can grinder at launity to grind it to matchThose heads have a smaller chamber than the 360 heads and will raise your compression. Since they are ported they should flow good enough. IMO, I would go with a bigger than stock cam to avoid pinging and putting that higher compression to good use.
I don't know if it helps or not but he said he balanced my motor
No torque I'm wanting to go with a 2200 stallDid it include the torque converter?
It's a LA motor and the trans is a 727 I know the magnum and and LA is opposite of one another just can't remember which one is eternally and whish is externally balanced just got done pulling my doner chunk for my 83\4 rear end going to clean it up tomorrow and check my axle bearing's the tag says its a 391Okay. Well do you know if it is balanced internally or externally? Could be balanced with the torque converter.
Whats state law, im from AustraliaState law here in Arkansas
State law to like Mopar, ..Whats state law, im from Australia
This is what we was talking about ..Thanks you got to love mopars ,state law in ky hope to finish this car this year
