Do these engine mounts look correct?
doogievlg
Amelia, Ohio
Took the mounts off over a year ago and went to put them back on and this is what I came out with. Looks a little strange.
Does not look all that wrong for /6 to V8 conversion mounts for a 73 up spoolmount K-frame. But i cant say for sure
could it be upside down? I never had a spool mount car.
is the distance between the spool holes the same on the k-member?
Here is a guess, they are on the wrong side: reason being that the offset of the motors centerline looks biased toward the driver side, and that is incorrect. Well see....
Ha, disregard: instructions look correct per instructions.....What happened?
