thats the ****....... the launch at 1.39 lets ya know its a MOPAR. whats the outside of the car look like?
100 mph??
One of the best dam cars I've ever seen.
The fab work and detail is second to none.
You've got every reason to be proud of your car.
Keep up the good work.
I might have missed it , but what rear gears and tires ?Thank you very much! I appreciate the kind words! I’ve grown with the car and pushed my abilities. I’m very proud of what it’s become! This site has been a very big part of that! I’ve learned allot from the members here that have bent over backwards to teach me! Thank you guys for sharing that with me
Car is kick *** ! Wish I had the coin to build a 68 dart to go w/ my 68 fish.
Nice. Whats the combo, sounds very strong? What carbs and tunnel ram did you use?
Here's a inside vid of my 67 Barracuda with 511 on QTP's.
Very nicely tuned and clean. I think those 470's are snappier than the 511's. Very simular build to mine, except i used a Molnar 4.25 stroke crank with MW victors and a 270@50 SFT. Whats the lobe sep on the cam? Whats the combo on the exhaust? Sounds killer.
ok, i have 2" header with 3.5 collector and pipe. Thinking about reducing to 3" exhaust pipe. Do you lock your timing or use a curve? Whats your max timing you found to work best? Thanks again and nice ride.110* TTI 2”-21/8” step headers into TTI 3” h-pipe exhaust into dynamax 12” bullets dumped in front of rear diff
are u running 3 1/2" all the way / don't reduce it , u will be able to tell the diff. !ok, i have 2" header with 3.5 collector and pipe. Thinking about reducing to 3" exhaust pipe. Do you lock your timing or use a curve? Whats your max timing you found to work best? Thanks again and nice ride.
Yes. My exhaust length is short at 36" using an oval race muffle simular to borla.are u running 3 1/2" all the way / don't reduce it , u will be able to tell the diff. !
