Hyper-pak alternator mount
pishta
I know I'm right....
Tustin, CA
where can I get one like this?
seems a way better place to hang this than out in right field! Modded PS mount?
That does look like what is on my A100. And mine also has a GM alt.
can you take a pic of the lower mount if your down in there one day?
I can do that . I'm all down in there. LOL I'll post a pic tomorrow.
Got bored. Looks kinda home made.
That alternator bracket (I'm sure) is the older GM one that mounted to the front of the exhaust manifold
60-61 Valiants used a drivers side mount. Chrysler Alternator. A100 vans also used a drivers side mount. If you have power steering, there is the issue. It looks cleaner but you need to beat the bushes to find a mount.
There are 4 threaded holes in the block at that spot. If you are handy with a drill, you should be able to make this work :
Summit Racing® Alternator Brackets SUM-G4050
Or, you can bolt a flat metal plate to the bock and make it long enough to bolt the alternator bracket to it, for adjustability.
it's been many years, but that's what I thought mine looked like. Painted not chromed, of course.
I just made my own. This is one on the race motor.
This one is tailored for one of the "mini" alternators.
is that a side draft carb setup?
Yes Phista, they are.....my friend own a metal recycling yard, he call me and said to take all I want for free before dismantling and shipping these combine machine.
I took 3 slants and have to leave 2 more due to health problem!
One was with a generator charging system.
that looks like a big B&S carb, no accelerator pump or enrichment circuit. One RPM...'RUN'.
