Leaking K-H brake line?
mopower440
TN.
Installing my new K-H setup on my dart. I bought new crossover lines for the calipers. Fluid is leaking where the rubber line meets the caliper line for some reason. took it back apart and dont see anything wrong, put back together and still sits there and drips..Anyone ever had this happpen and what was the problem? It didnt leak when i had the drum brakes on 3 weeks ago..
Yes.
Stainless lines?
I used the plain Steel ones and still had to tighten and loosen a few times to get seal a good seal!
Yes.
Stainless lines?
, not stainless, i got just the regular ones..I have took it off twice and put it back on and still wants do drip..why would it do this? Is it the rubber line or the metal line at fault?
Your guess is as good as mine. I would suggest bad flares against other products. Loosen and tighten them again while using the correct tools.
