So I finally dropped the engine in last night it looks amazing. 6 weeks of hard work i went thru every nut and bolt bearing and runner.
THIS IS THE PROBLEM: is the second compression ring upside down? Is the ring's face cut at an angle? Im pretty sure its not because its a low compression motor and ive only seen this on hypo.
i put new rings in( chrome moly top ring (faced) iron second ring stainless oil ring). Sealed power 5/64 5/64 3/16
I clocked them all correctly coated with 5w20 an installed TOP ring facing up. Just didnt check the 2nd ring's face.
Ive rolled it over plenty of times, i lapped the bearings. It felt really good at the crank and plenty of compression
