snailpower
hi guys, I haven’t seen this posted anywhere so I thought I would get the group consensus.
I recently installed these adjustable qa1 strut rods that are a bit thicker diameter than stock and are now hitting my sway bar end links on both sides. It’s a firm feel sway bar. I tried rotating the upper mount tabs to face up and down, no luck either way.
The only fix I can see for this is the sway bar to be wider.
Any ideas?
Any ideas?
