Contact @Johnny Mac He is a member here and a Vendor, If your looking for a complete assembly.
Thanks for the shout out @SGBARRACUDA ! Yes happy to talk crate engines any time. We just launched a new roller beast, but still have the base versions hanging around too. Thanks a bunch! Chrysler Compatible Crate EnginesContact @Johnny Mac He is a member here and a Vendor, If your looking for a complete assembly.
Well the search goes on. We were too fare apart and then shipping. I'll wait and keep my eyes open , but thank you to all for your input its all good info. The block was a good block , clean inside none molested
stock.
OK sounds good . PM me when you get back. We'll go from there.Hang on until I get back. I'm leaving in the AM to go to PDX for a doctors appointment on Thursday, spend some time with my parents and make sure they aren't going off the rails and then I have to run to Salem and help a friend. I'm hoping to be back home by a week from Thursday. I have a block here, and some Pistons everyone hates and probably some rods. Cranks...I have to look.
Let me know what you need or want. If I don't have it, I can usually scrounge it up.
right rumble
but cheap rollers or without a B3 type geometry fixer are a waste of money
do it right
As one of my engine shop owners sez.."when is the last time you saw a Mopar crank break....never".Yes and no. While a cast crank is a down grade, there still plenty strong. The low compression pistons are as you say, easily changed out. Even so, a set of closed chambered heads will raise the ratio to a reasonable level. You'll need to know exactly where the piston sits, the head gasket dimensions, valve relief amount and head chamber cc amount for the calculators. Getting to a 9.0-1 should be easy enough. More is better. But lets see where you end up first. At 9.0-1, thats enough for most street cams to perform vcery well.
Who was the guy with an OE 360 short block & W2 heads? Running low 12's IIRC? It is a great and cheap combo. He invested in heads, cam and valve train. BAMM baby!
Yellow Rose your inbox is full.
Soon myself.... did ya see my PM?Cleaned it out. I'm going to get a gold membership so I have more than 15 PM's.
I know how valve guides wear with bad geometry, push rods rub, can't run large diameter pushrods - which really help
roller rockers do not help most with the size cams -under 550 lift that are buying them
spend your money on something else
Just doing the research Del. Ive seen the prices on 340's IMO over pricedRichard, I would not pay "extra" just because it's a 340. In many ways, for "non restore" and other reasons, a 360 is more bang for the buck.
'Theme of the build' is understandable. And besides, when you mention those 3 magic numbers '340', a lot of car nuts start slobbering. My son and I went for a 340 for the same type of reason... and the reactions to the word '340' are hard to explain.. but it is like magic to some folks.Just doing the research Del. Ive seen the prices on 340's IMO over priced
but it fallows the theme of the build.
There are plenty of 360's around here
for reasonable prices if I can't settle on a 340.
LOL.... I just can't go that far. No matter that the only thing '340' in it is the block and the oil pump.....Then run a 360 and tell everybody it's a 340... Both engines look the same from the top when they are in the car... They won't know any better...
LOL.... I just can't go that far. No matter that the only thing '340' in it is the block and the oil pump.....![]()
