Stop in for a cup of coffee
I have some.
Here's the 51. It's a real pile. Customer wants it on the s10 frame with NO body work whatsoever.
Here's the s10 frame with the CODE504 kit on it to accept the 51. It's a nice kit. Labor intensive, because you have to cut all the cab and bed mounts off the frame, locate and drill new holes for all the new cross members and brackets, but it's really straight forward. You can see all the new stuff. It's grey and unpainted.
I have a few more, but I have to run for now.
When i saw mention of the 504 kits i went on the website and took a look. Impressive. Would save many hours in fabwork. not terrible expensive if you consider the end result.
I would be further ahead to put my cab on a newer chassis, but just want to bring this one back to driveable. It would have to be a dakota chassis for me.
I am just wading thru snow stringing my extension cord to my rail tug. At least it has not started getting really cold yet. And snow is not to deep yet. Won’t be long I will have a ten ft deep tunnel cut thru the snow for rail cars. Long winters up here for sure
Guess i should go finish this lincoln. Install motor mount and reconnect exhaust.
