[Found!] Abody 318 manifold exhaust
victa15
Tucson
Im looking for a pair of 318 manifold exhaust turn down pipes. I think thats what they are called. I just need the section that connects to each manifold and goes under the car. I have a 68 valiant with manual steering. Thanks
are you looking for the y pipe that hooks up the cast iron exhaust manifolds?
Yeah. I want to put dual exhaust using the stock manifolds. So im either looking for the y pipe or separate pipes coming down. I dont have 100s for an exhaust right now
I have y pipes, but they are expensive new and used. shipping will kill you because of the size.
you would be better off having an exhaust bender make you up the ball connections for your exhaust manifolds. think about it no old rusted pipes to weld together. you may even be able to get them through your local parts store, just tell them what you have planned.
I have a pair. I can send a pic later this morning.
What size diameter, stock ? 1.5"?
