[SOLD] Magnum Hydraulic Roller Cam
subcom
South Florida
Oregon grind #1357. Specs here.
Hydraulic Roller Camshaft Specifications
Great cam for you Magnum swap guys. With EQ heads and a stock 5.9 Magnum my car went a best of 7.90 in the 1/8th N/A with this cam.
Video of first start of the engine with this cam. Has a nice idle.
$175.00 shipped to the lower 48. PayPal only please. Located in S. Florida. Thanks
Will a fuel pump eccentric bolt to this cam or is the Hughes kit required to extend the cam snout?
The Hughes kit is required. I can include the eccentric and the one or two pieces I’m not using from my Hughes kit.
Were you able to use this cam with stock magnum lifters and intermediate shaft? Or does it require a bronze gear / aftermarket exposed wheel lifters?
I used the pushrods I listed above with the original lifters, rocker gear and intermediate shaft.
I'll take the cam if it hasn't been sold already. PM sent
