YesYou ever use epoxy primer?
Don't see many pack rats in my area. Damned squirrels raise a little hell.How's the weather up there? Beautiful state! Pack rats hibernate or burrow deep and still wreak havoc all winter?
I use Omni too. Never seen it bubble Trip.Lorenzo national?? Forest they were all over the place. Ooh omni was what I used,your link didn't take me anywhere I'm thinking that stuff was $125 a quart plus activator seems to be tough as nails though
Ya pretty close to the KootenaiDamn spell check kootenai forest
You are getting lots of opinions. I have been painting cars for almost 40 years. All self taught, but I do pretty well if I do say so. I will say that you can do an acceptable job with an inexpensive gun. However, the better guns will give you better atomization. I would HIGHLY recommend the Devilbis FLG4 Finishline gun. That was my main gun for several years. I also have a Devilbis SRi Pro touch up gun that is amazing for smaller tasks. I recently retired my FLG4 to primer duties and bought a Iwata Super Nova. Bottom line is that if you can afford a few hundred dollars for the FLG4, it is an excellent gun that will last a LONG time if you clean it thoroughly after each use. Buy a few extra tips and you will have Priming and painting covered. Another advantage of buying an FLG4 with tips for painting and priming is that you can practice spraying technique while priming, and by the time you put on color and clear, you just might have it down pat. Also remember that a paint job can be NO BETTER than the prep. I painted my Barracuda with a Devilbis, and it came out pretty good. Feel free to PM me if you have any painting questions at all.I paid a guy to paint my 67 dart and it came out beutiful.
I laid primer with an older suction gun which was new in the late 80s.
From time to time I have painted farm machinery with it.
Now I have been working on a 96 reg cab short box dakota with a big block swap. I am planning to save some money by painting it myself. I also have a 1931 model A in line for paint.
I am no professional painter and I know I cant compete at that level.
Air compressor is not an issue or concern.
I am looking at a new gravity fed hvlp gun. I see the devilbiss finishline guns at the $200 price range. The old suction gun can still lay the primers down. Mainly thinking single stage paints.
Is this a good gun for the price or are there better options in this range?
OK so that is where a few drops dripped from! I just fixed those few spots an continued on. I bet you are right about the lid. I had or have another cheap guy with a metal tank. Don't remember any problem with it. I have used different epoxy primers, some require time to activate, others not.They work good as long as you aren't spraying epoxy primer, the chemical reaction creates a lot of heat,the plastic kids swells,and guess what happens next??
How do you like the super nova? I've been using mine for about 8 years now and bought the Entech too. I wouldn't go back to a sata.You are getting lots of opinions. I have been painting cars for almost 40 years. All self taught, but I do pretty well if I do say so. I will say that you can do an acceptable job with an inexpensive gun. However, the better guns will give you better atomization. I would HIGHLY recommend the Devilbis FLG4 Finishline gun. That was my main gun for several years. I also have a Devilbis SRi Pro touch up gun that is amazing for smaller tasks. I recently retired my FLG4 to primer duties and bought a Iwata Super Nova. Bottom line is that if you can afford a few hundred dollars for the FLG4, it is an excellent gun that will last a LONG time if you clean it thoroughly after each use. Buy a few extra tips and you will have Priming and painting covered. Another advantage of buying an FLG4 with tips for painting and priming is that you can practice spraying technique while priming, and by the time you put on color and clear, you just might have it down pat. Also remember that a paint job can be NO BETTER than the prep. I painted my Barracuda with a Devilbis, and it came out pretty good. Feel free to PM me if you have any painting questions at all.
View attachment 1715455647 View attachment 1715455648
Haven't used it yet. I do have access to a real paint booth, but it isn't heated, so it will be spring before I get a chance to use it. I called the US headquarters for Iwata and talked to a guy named David. Really nice guy. He talked to me for about 10 minutes; which impressed me since I am not a professional. I told him that I could not really afford one gun for basecoat and another for clear. So he recommended the 5935 with the 1.3 tip. He said you don't really need two guns and that I would really like the 5935. Also, I have been using the DeKups disposable paint cup system for several years now. It is really awesome since it cuts down on gun cleaning time and allows you to spray holding the gun upside down.How do you like the super nova? I've been using mine for about 8 years now and bought the Entech too. I wouldn't go back to a sata.
