1969cuda
No problem, glad to help.
I did read that in the catalog. Interesting option to have black paint below the trim. I’m trying to find a pic of that online. I see a few with the trim, none with the paint too
He sent me the pictures, I’d guess it to be about 6ft and 2 inch across. Like the normal trim, rolled edges in, just bigger. It was anodized aluminum if that helps?
In the pic I posted, the top left clip is a reproduction that does/will View attachment 1715488379 not work, the top right clip is the first clip for either side on the front fender, and the bottom two are originals that have broken tangs. No part numbers on them what so ever. I have twenty or so of them, in various states of disrepair.
Dan fill the holes in the body and sell it for 1 million dollars. All your problem is solved
The metal clips look easy enough to, again, have scanned in like the plastic and then just laser cut out of a stainless steel sheets so rust isn’t a problem. While I don’t have the capacity for that where I am currently, I have tons of friends with tons of friends I’m sure I can find someone easily, I’d be glad to do the work to have all this stuff repoped and then sell it back off at slightly above cost.The end metal clips you can probably find something for another make vehicle that will work. Try AuVeco clips and fasteners. They may have something close.
Having these made from stainless steel would be much better than the anodized aluminum.
Got my hopes up lol. I've found one side, but still looking for another or a complete set if another spare cant be found.I thought I had some nos clips but they don’t look the same.
My TP dealer came through big time last night. Got me a 24 roll pack of Angel Soft. I'm gonna cut it with some fast food napkins from the glove compartment, then already got people wanting it. Got a mule to deliver it too. I knew I'd find a way to finance my Mopar projects, lol.Damn, that is worth more than a million bucks. You drive a hard bargain.
Here is the pic I missed.
The two bottoms clips are shown front and back. You can see what’s left of the broken tangs.
what do they measure?Close, but no cigar. These clips are extremely hard to find in usable condition.
Pretty sure the white clip on the left is available through AuVeco clips and fasteners. It snaps into raised spot welded lugs. These can easily be installed with pop rivets. If not theres plenty of GM clips there for wide rocker mouldings.Here is the pic I missed.
Those can be modified to move the stud in closer, or easily be reproduced that way.I thought I had some nos clips but they don’t look the same.
Those clips are sold by fmmpar on eBay, specifically for these moldings, but do not fit.Pretty sure the white clip on the left is available through AuVeco clips and fasteners. It snaps into raised spot welded lugs. These can easily be installed with pop rivets. If not theres plenty of GM clips there for wide rocker mouldings.
Sorry couldn't remember who had said it, just remembered what you said. You kept me from ordering them, so thank you for that. Of course finding out I only had one side put a damper on it too, lol.That was me
