1973dusterkid
Watch This
Abody Mopar 4 speed setup Plymouth dodge
1300 or offer/trade
Non overdrive 4 speed iron case aluminum bell housing. Transmission works good, I ran it behind a 360 in a 73 Duster for a few years, everything has same wear but still works good .I am now going 6 speed. Transmission is ready to install, but one of the trans to bell housing bolts needs tapped. This is almost everything you need to do a 4 Speed swap, minus so clips and bushings. Hurst Shifter was rebuild by hurst a few years ago. Has a orange 35 tooth speedometer gear, needs a new rev light switch. I also have a 360 external balance flywheel, I can include for the right deal. Located in Buford Ga can ship at buyers cost. Trade for motor parts or other guy stuff.
Included is Transmission, Bell-housing, Shifter and linkages, clutch fork, Zbar and linkages,inspection shield, and crossmember
1300 or offer/trade
