Looking for a set of either single or double adjustable shocks for a 69 Dart with super stock springs/stock ride height
Let me know what you have
thanks!
I've got a pair of Afco double adjustables with a hundred or two miles on them that came off the same rear suspension set-up on an E-Body. They have hiem joints on each end.
Your mailbox is full but how much did you want for them
1/2" The stock sized bolts fit through them, but I did have to use washers/spacers as the heim joints themselves are more narrow than stock shocks rubber bushings & sleeves.What are the size of the heim joints?
