black954
Can someone please confirm I have these installed properly. They are the original mounts from the 340 in my 69’Swinger bolted to a 99’ Magnum 5.9.
The photo makes it looks worse than it really is, but no, they are not exactly in line with each other. I was more looking for if they are in the correct orientation or if I have them bolted in wrong. I took the motor out of the car 25 years ago and don’t recall how they went LOLNot sure if it is the photo, but the bolt in the first photo on the right looks a bit wonky, like at an angle and the threads look to have been newly damaged. Second photo look similar. I would figure the bolts would be parallel to each other.
Awesome, thank youLooks correct. 65'
