Thread size wheel stud?
sabre67
B.C. Canada
Can you use 12mm wheel nuts on 1/2 wheel studs? Thanks
No, the 1/2 is actually closer to 13mm. Also, the thread pitch is different between metric and standard.
No. They are 1/2-20 UNF. Pretty common lug nut used on many makes.
A M12 if you could get is started would strip and make a mess of the stud and the lug nut.
Go see Duncan at south side auto he’s a mopar guy .
Met him at a car show years ago ,kept in touch with him ever since he’s a buyer and seller of parts in the place you live .
And just for future reference, the answer to the question "Can I use a metric nut on an SAE stud" is always "HELL, NO!"
