2 Holes
sabre67
B.C. Canada
in the firewall i dont reconize. About 3/4 size heres a picture there is red plastic plugs in them im stumped 70 Dart
i cant see it in yor pic what goes threw them?
I'm not near the car, but it's a 69 cuda and the lower hole near the master cylinder has the speedometer cable. The top hole has wires. Right click on the picture, save it to your pictures and then expand it on your computer.
Upper right bigger hole (about 1-1/4") is the place the washer foot pump 2 hoses went through a double-holed grommet. One hose was from washer fluid bottle to the foot pump and one was from the pump to the washer nozzles. The smaller one closer to the master cyl is the speedo cable hole.
Just working on same things on one of my Demons - hope it helps!
Mine doesn't have a foot pump, it's electric, that must be the difference
A pic of my 69 Dart
The hole on the left looking rearward, speedo cable. The hole on the right, foot pump washer hoses.
Sabre 67, Do you have the Speedo cable in?
Expanded for you.
No cable on order, I just got the car 2 days ago still finding little things minor things
When you don't have the manual foot pump washer, but have electric, then that hole is covered by a black rubber plug.
My dad was a Fuller brush salesman and went on many long trips. The firewall was all rusted from from him peeing through the holes.
Are those manual washer systems repoed or just changeover now? Electric seems like a simple idea? Electric would mean some king of new wiper switch?
Repoed? The 3 speed wiper option included the electric windshield washer which is activated by pushing in on the dash mounted switch. Note the 3 speed wiper motor is longer and parallel to the firewall and the washer motor is under the washer fluid container.
What i meant is the manual pump reproduced to buy or do i need to change to electric now I would like to keep the original wiper switch. wiper work good just need some kind of washers
if you want used, post what you want in the "Wanted" section or check ebay, if you want new (reproduction)check the FABO sponsors section to see if it's offered.
