Ron816
Mopar forever
8 3/4 diff should the axle bearings be greased?
Yes and that reminds me, I need to pull mine and do that. They are a little noisy. I never worked at a Mopar dealer but I always thought they were lubed by the rear end lube. They are not.8 3/4 diff should the axle bearings be greased?
Or you can take out the tapered roller bearings and install "Green bearings" which are sealed double ball bearings. There are 2 different styles. I kind of like the flanged Mopar Performance style sold by Summit.that's why I asked
Yep. I owned many Mopars in the last 50 years and never had a 8 3/4 apart until a few years back. Never had to. LOLThe grease seal between the bearing and the center section is a sure giveaway!
7 1/4 going on 318,000 miles! No entries in logbooks.never had a 8 3/4 apart until a few years back. Never had to
If your real axle bearings are making noise, it's too late for grease to help them. You'll need some new ones.Yes and that reminds me, I need to pull mine and do that. They are a little noisy. I never worked at a Mopar dealer but I always thought they were lubed by the rear end lube. They are not.
