For my 160K mile, 4 banger, a wad of TP in beer can would be fine. Just need to stop nuts, bolts, small animals...German built filters are generally Good..... Ja, ich spreche auch deutsch
Those I had today are 'regular' filters. I think most brands (even Fram ) are OK if you go to the better lines they make. I have been running the next level PUR in the Duster. Also run better in the Journey and always did in the Magnum. If you have a high dollar, tight, new motor to protect, it makes sense to spend the extra for the best filters. When our old Mopars were new probably MOST were using the low end Fram and the factory recommendation was to change the filter EVERY OTHER oil change.
