Do Mopar Brackets Ever Have Part Numbers on 'em?
dibbons
La Paz, B.C.S., Mexico
Trying to identify this bracket which I believe is Mopar related. All I could find is the word "top". Thank you.
Hello dibbons,
I believe that to be one of the three brackets that mount the Power Steering Pump to the motor. Goes between (towards the rear) of the bracket with the slots and square hole for adjusting the belt tension. The Top indicates that it faces up towards the hood.. Two of the bolts go to the water pump and the other goes to the long bolt that goes through the bushing connecting the two pump brackets where the pump would pivot when adjusting. And not sure but when i restored all my brackets I did not find any part numbers..
Stay Safe...
Happy Mopar :)
Arron.
I agree. That is a small block power steering pump bracket.
Yes, small block power steering bracket. I believe its for Saginaw pump. No part numbers on those that I am aware of. They stamped part numbers in larger brackets like bumper brackets.
Yeah that is normal. If I remember right, that bracket bolts on to the timing cover.
