Will stock factory Chrysler 400 cast pistons hold up to 6-8 PSI of boost if driven responsibly? Thank you drive through.
If driven responsibly means avoiding detonation at all costs, then yes, no problem. That may require a target closer to 5 to 7 pounds of boost, depending on your cylinder heads, but really splitting hairs. Sounds like fun, BTW!
Oh, definitely cool, and maybe way too much fun, ain't nothing like roots boost. Okay, I was thinking around maybe 8.5:1. with 7.7:1, 8 pounds of boost is no problem. Especially in something that light. Looking at what, around 3000 pounds with driver and a blown big block?
I hear you there'll be plenty of retard in the car already......With 7.7 compression and 5 PSI boost, yall really think it's need boost retard?
You don't think going from a slant 6 to a 400 going to be enough of a step?.
Sure, but it's not gonna happen anytime soon, plus, I've always wanted to build another blower motor.
I would. Or use some really good gas, like 114 or methanol/water injection. One good round of detonation on those cast pistons and they're gone.With 7.7 compression and 5 PSI boost, yall really think it's need boost retard?
About 36 degrees of static timing with the coldest plug it will reliably run with and 20 degrees of start retard and you’ll be fine. Somewhere in the 12-1/2 % under drive range should deliver around 7 pounds of boost. The water meth injection is a necessity, though.With 7.7 compression and 5 PSI boost, yall really think it's need boost retard?
