- Joined
- Mar 17, 2018
- Messages
- 16,054
- Reaction score
- 38,639
He owns ya now Chris!
Ahhh. I gots some o dat......sell it at home depot.. or Zippo fluid..
White gas...Ahhh. I gots some o dat......
I will have to remember this when you want something delivered in my piece of **** Ford to your place......![]()
Unless I had tohaha yeah but you own at least 3 Mopars, that means you have a net of 2, so it balances out
besides, you already said you weren’t coming back out to the land of corn and soybeans again![]()
It was all about are you sure you are going the right way? A dozen turns, at 3 in the morning, pitch dark....haha yeah but you own at least 3 Mopars, that means you have a net of 2, so it balances out
Is that a non brother Fart ????White gas...
Haha you did well. If that interstate exit hadn’t closed out of the blue, you’d had 3 turns and 1.5 miles off the interstateIt was all about are you sure you are going the right way? A dozen turns, at 3 in the morning, pitch dark....
So i decided to close up shop to the public. No visitors.
With all that’s going on, i think i can afford to shut down for a couple months if necessary.
Total stranger rolls in and is looking for a hubcap/wheel cover. Code red obviously has no meaning to that guy.
nothin...What's up old man club
I not be old!What's up old man club
I just finished up painting this for a guy and, put the stripe on. Not sure if your doing it on a Dart or not but, it wasnt bad to put on with the exception of where the valance meets the quarter panel. I have seen them cut and wrapped in between the panels and, just layed over(if that makes sense) I took a razor blade a center sliced it so it layed down in the small gap between the panels otherwise it had a huge air pocket there and wouldn't lay down right.I readjusted the trunk panel, so it sits right in the corners and adjusted the latch so it is down even with the rear of car. I already have the Bumble Bee Stripe for the car, and am getting ready to install that. ( never did one of those either ). Now working on the center console, re carpet and have a nice inlay from DMT. Probably get the kick panels in today and maybe the console...Slow but Sure....
Beautiful dartI just finished up painting this for a guy and, put the stripe on. Not sure if your doing it on a Dart or not but, it wasnt bad to put on with the exception of where the valance meets the quarter panel. I have seen them cut and wrapped in between the panels and, just layed over(if that makes sense) I took a razor blade a center sliced it so it layed down in the small gap between the panels otherwise it had a huge air pocket there and wouldn't lay down right.
In dog years you are old.I not be old!
Hi rainyWhat's up old man club
