thomasfouraker
I have two camshafts on hand and am hoping one will be suitable for my plans.
Being that I dont know anything about the numbers on camshafts, I hope the community can take the information I do know and can provide me the best option.
2000 Dodge Ram 4x4, trying to keep power low...... idle-5000
Keeping EFI
Hughes Airgap
408 9.0:1 compression
RT 2.02 Heads
KB356 pistons
Eagle Forged Crank
Eagle Forged I beam rods
55mm F&B Throttle body
Cams on hand are:
Hughes HER1828ALN
Comp 20-746-9 XR265R-14
Springs are Hughes 1110 good to .550"
I have the option to use 1.6 or 1.7 Roller rockers to adjust lift accordingly.
Below I will attach each card.
Here is the catch, within the next year I plan on adding a Kenne Bell Supercharger that should provide 6-7 lbs boost. Ideally I would use a Cam that would not need to be swapped out at that time. I am gapping my rings for the boost now with future plans in mind.
Keeping EFI
Hughes Airgap
RT 2.02 Heads
KB356 pistons
Eagle Forged Crank
Cams on hand are:
Hughes HER1828ALN
