1969dodgedart
Big Block 440
I've ordered 20-7 from summit to see if this centers / levels cable pull . Plan B will be to have my buddy machine me a pin that bolts directly to the carb arm that corrects the issues since the only thing I'm using mopar is the cable so if the pin diameter is same as the eye and I use the right hole for height I'll be good to go .
