How Are You Fastening Your Side View Mirror?
dibbons
La Paz, B.C.S., Mexico
The two sheet metal screws holding the side view mirror on a '65 Formula S and '65 Signet convertible are not doing the job. Mirrors always seem loose. What is your better idea? Thank you.
Install 8 or 10-32 nutserts into the door and use stainless screws to hold it in place. If the door panel is off you could use an 8 or 10-32 screw with a nut on the inside. If you ever have to take it a part again you'll need to remove the door panel obviously.
Find appropriately sized (similar to the original sheet metal screws) chrome or stainless oval head machine screws, then use the corresponding size nutserts (also called rivnuts) in the door panel.
nutserts - Bing video
If the mounting holes arent violently stripped, they might be warped upward from tightening. A pointy body hammer or small ball peen can flatten the holes out and smallerize them a bit. Helps if you can get a dolly or something inside the door as a backer for the massaging.
The mirror on my 64 kept loosening up. I bought the correct gasket from DMT and installed it. That seems to have fixed the loosening problem.
But if it persisted I would make a nut plate out of bar stock, say 1/8" x 3/4" long enough to be longer than the screw centerline dimension. Tap the nut plate in 2 places. Install it from inside the door and use 2 oval head machine screws with loc-tite through the mirror and door skin into the tapped holes . I'm guessing they woild be 10-24 UNC but you'll have to verify the size. 10-32 UNF optional.
What side view mirrors?
I don't have any..............
I'm sure Someone will be offended but, I used these, used smallest I could find. Had to drill holes a little larger. been holding fine for about 10 yrs.
Do they make those in stainless, with phillips head and countersunk? None I've seen.
