What is the year and numbers on the blockJust wondering, without tear down, is there a way to tell if the pistons are below the block deck, (low compression) or above the deck (higher compression).
It is a 1970 date code, I’ll have to look to get the specifics.What is the year and numbers on the block
Great picture! Thank you fellas so much. The engine has been modified at some point. It has an Engle KV-2 flat tappet cam and edelbrock rpm air gap, some other upgrades. I am going to purchase performer rpm heads and wanted to get the correct casting for low or high compression block.
That's a 12.5:1 TRW, not a stock piston. lol
Those are not stock 340 pistons.
Not to hijack but is that 68 4 speed cam available? I run the Summit 276/288 duration 441/441 lift cam in mine. I seem to think that's "close" LOL! They are also very affordable. The 68 specs are to the best of my knowledge 276/284 duration .444/.453 lift but there is a caveat that duration isn't at .050 or something.Das more like it! Although it's a TRW replacement, it's still about the same as the 68-71 piston.
That's always been one of my dream builds. To build up a blueprinted 71 340 dead stock but with the 68 4 speed cam with everything machined to perfect spec and stick it in something light.
Never happen. LOL
Yup. With a milled domeThat's a 12.5:1 TRW, not a stock piston. lol
L-2322?I have an old set of TRW s that aren't that aggressive in the dome probably 1/2 that height I seem to think the number is 2332 or something like that.
I am sure yes. They are old stock I bought the car in 93 they came with it. I had those pistons and a crane ssh 320 nc cam. I still have everything the cam is rusted and has pits though its a shame it seemed like an aggressive setup when I had it together. i wish I could still run that cam. i suppose i could but I fear the cam would start coming apart in small metal shavings as it has pits in the lobe surfaces.
They're on...what am I missing?Put your glasses on.
Here is what they look like out of the box...
