Blucuda413
Does anyone make a kit to install a late model Challenger IRS suspension under a 67-69 A Body??? If I buy a car for the engine it's a shame not to use as much of it as I can to upgrade an older car!!
You’d be better off to do a body swap. Cut the chassis out from the challenger and cut the frame and floors out of the A body. Probably have to widen and lengthen the body to make everything fit, or shorten the challenger chassis. Just depends on your willingness to experiment.Does anyone make a kit to install a late model Challenger IRS suspension under a 67-69 A Body??? If I buy a car for the engine it's a shame not to use as much of it as I can to upgrade an older car!!
You never know 'til you ask! At the very least, crawl underneath with a tape measure and start eyeballin' everything.Only thought it would be nice to have a modern suspension under an A Body. Asked about a kit because other cut and weld work might be minimal. Obvious by responses that it won't be done because my engineering/welding capability sucks. As with many others just a thought that won't pan out!!!
Agreed. We’re in the middle of putting a 48 dodge 2 door business couple on a 2006 Charger SRT chassis. Surprisingly, it fits dang near like a glove.You never know 'til you ask! At the very least, crawl underneath with a tape measure and start eyeballin' everything.
There’s a gentleman over on Moparts that took a c5 corvette suspension and stuffed under a 73 cuda. Anything is possible, just depends on your skill level, time and moneyOnly thought it would be nice to have a modern suspension under an A Body. Asked about a kit because other cut and weld work might be minimal. Obvious by responses that it won't be done because my engineering/welding capability sucks. As with many others just a thought that won't pan out!!!
