small wheel bolt pattern and pretty sure its a 7 1/4 and vin is in picture but who knows what was done by previous owners
No fender tag or broadcast sheet ,The fender tag or build sheet would tell what the rear axle should be. But it is an H code.
Could be anything who knowsRear end's obviously been swapped. It's an old car. There could be a dead body in it somewhere.
Or for homemade lawn tractor use. But if it has low gears or a Powr-Lok differential, someone will want it. Let us know what you find on the tags on the cover if they’re still there or under the cover if they’re not.7 1/4" axles are the weak-suck axles ---> garbage...
I broke 3 of them in 4 years behind a mild 318 with a 4 bbl...
The only thing they are good for is a stock slant 6...
It would seem to me that a previous owner kept the 8 3/4” out of the car, and just swapped in the 7 1/4”. So, the drums would be worth saving, they will fit a small bolt pattern 8 3/4”, but the rest is not worth much, unless you have a project car that needs to roll around the driveway. I usually keep one around for that purpose.
Not if it has 9" brakes it won't.
Need pictures, but should be worth something.Are these wheels worth anything Magnum 500 Wheels 14 X 5 1/2 Tire And Rim 5 On 4 1/2 Bolt. / Matching set from a 1972 challenger 340 car
I will have to get them down and get pictures and repost , all center caps and trim rings are there , and have no use for them , debating on sellingNeed pictures, but should be worth something.
are there any frame numbers to match the vin ?
there r guys buing them up & modifying them for off road usewhat's a original 7 1/4 duster rear end worth ? I am going to sell mine as I upgraded to 8 3/4 and could use the money back. Also have a set of 4 aluminum slots small bolt pattern , and the rear wheels are wider than front , may be factory unsure but what would a good price for the wheels be ? May list them here but would be local pickup , just trying to find a value at the moment before listing locally on market place or craigslist
