What Radiator, Shroud and electric fan should I use for my 360?
67DodgeDart360
Maryland
What Radiator, Shroud and electric fan should I use for my 360? I have a 67 Dart with a 74 360 Engine. I need left upper inlet and right lower outlet.
Will this work?
Mopar Radiator 22" Cuda Challenger Charger Road Runner RT Superbee 1970-1972 | eBay
Look for 70 up radiators. They should have the in and out on the correct side for your 360
IMHO stick with oem style stock copper brass HP/AC radiator, and an OEM shroud and a fixed 7 blade OEM fan. No need for a clutch fan, they do nothing for cooling.
Electric fans seem cool but so many people put them in and have issues.
'70 and up aluminum pump, inlet pass side.
'69 and down cast iron pump inlet on drivers side. Forgot to say, the cast iron pump is 3/4"" shorter. If you go with an aluminum radiator, and the Hayden 2947 fan clutch, you will probably want that 3/4" of space, may need it anyway.
Your inlet is on the bottom, outlet on top.
That's the aluminum pump, '70 and up. Have no idea what that radiator is for.
That depends on whether you are talking about the radiator or the water pump. :D
