[Found!] Rallye Wheel Center Bolts
eekvonzipper
My Member is Legendary!
Cadet, Missouri
I noticed a Loose Wheel Center today...
I pulled the wheels and saw that I only have 3 bolts in each Wheel Center.
Does anyone have 8 of these that I could get?
I have the Small Bolt 14" Rallye's
Thank You!
Just use 1/4 20 1/2 inch long bolts, use lock washers so they don’t get loose on you.
Check your threads, they fall out sometimes when the threads strip. Mine had some sheet metal screws in them from a previous owner. They are just pot metal I think, so be careful tightening.
Yes if threads are gone install heli-coil repairs and they will then be permanent.
Older cars used 3 even when there are five possible locations. Newer cars, or centers with stripped holes can have five or just used as needed.
The pot metal in mine was soft, and a couple were stripped. The old parts store heli-coil kit fixed them.
When using non factory bolts , it's a good idea to check and see if the head of the bolts don't extend out too far. They could interfere with the wheel seating on the hub on your car correctly.
Frank
He's right. I had to grind the bolt heads down on the replacement part store bolts. I had to paint them light argent, too, so they didn't stick out.
