Demon fender extension trim help
Fast340cuda
San Jose, ca
I’m starting to assemble my basket case 71 demon and could use a little help identifying some hardware. Anyone have pictures they could post of the correct fender extension trim (eyebrow) mounting screws? Guessing 70-71 dart would be the same?
I believe its a machine screw (maybe 10-24).
Are your extensions fiberglass or metal?
I would think (not sure) that the glass ones would use a screw more like a sheet metal screw. I dont think I have any fiberglass ones here to look at.
I’d be interested in any info on the cast aluminum extension/trim hardware if you have it available!
I found a pair of extensions that had the original screws in it. These were from the aluminum extensions. Its a 10-24 screw 1/2" long. Heads were painted black to match the bezel.
