Oil reserves
MomsDuster
Vacaville Ca
Ok I understand that there are many variables but I’m looking for an approximate. Let’s say a 440 with stock pan and a total of 5qts including the filter. How much oil is actually in the pan with the engine at say a cruise rpm of 2800?
Good question.
It all depends on how good your drain back is in the block.
If you have a high volume oil pump, it becomes more of a concern.
My guess is that you would have at least 3 quarts in the pan at that R.P.M. with the rest in the engine either coming or going.
As your R.P.M. increases, you're at the mercy of the drain back so you don't ''suck the pan dry.''
That's when high volume oil pumps and higher volume oil pans come into play.
Here is a decent article to read on the subject.......
Around and Around - Where the Oil Goes in Your Engine
Windage tray or crank scraper will increase the oil in the pan. Lost of oil clings to the crank without these.
Good question.
Total oil flow in any engine is the combination of all the internal leaks. Once you supply all the leaks, the oil pump can’t force any more oil through the system and you start to get pressure, which is resistance to flow.
The only way a pump can suck the pan dry is if the pan is too small to start with for the oil flow through the engine, the pick up is too far from the floor of the pan (which really isn’t sucking the pan dry but the result is the same), the oil is trapped in the engine and cant back to the sump.
As pishta pointed out, windage trays and crank scrapers are a huge help. Pan design is a big deal as well.
I had a customer who calculated his engine’s oil flow. He needed 10 quarts in the pan to run 170 plus MPH and end up with a quart in the pan at the end of run. He purposefully made the heads trap oil so it wasn’t falling back on the crank. He had little margin for error, but when you are trying to set a National Record that’s the kind of stuff you do. And the rules said wet sump only or he’d have used a dry sump.
Man that is the kind of crazy stuff I like. Dragster in the late 1950's or early 60's kept losing more oil pressure during each run. He kept on adding STP after each. Final run was on straight STP. Won the final that day if'n I'm remembering correctly.
And he set and reset the National Record several times. Best natural driver I ever personally ever had the pleasure of watching. I looked at most of the downloads from his most of his runs and he was spot on his shift RPM. I didn’t get to see Ronnie Sox drive, but I wish I had.
I saw him quite few times , if I ever had a hero , he was it ! The guy was fantastic !
