Brandt Fonda
Hey guys been reading up on Nitrous applications on the forum and internet, I believe I have got a good setup and was hoping some of you more experienced guys could give me a peer check and make sure I'm not missing something. I'm wondering if it would be "safe" to run a 150 shot on 93 octane pump gas with my setup?
360 la, 9.8:1 CR, forged pistons gapped 30, stock rods/crank, bored 40, Hughes engine cam 546/563 duration 236/242 108 lsa, 308 heads 202/160 multi angle with some mild porting/polishing work, Hughes roller rockers, M2 intake, TTI 1 3/4 headers, TTI 3" x-pipe, Holley Sniper 4150 TBI, Holley dual sync distributer (controls timing), Sniper NOS plate w/150 jet. Champion RN11YC plugs. Drivetrain: A833 32 spline 4 speed, 8 3/4 409 rear end w/ Eaton Tru trac and 3.91 gears.
min/max rpm NOS activation: 3k/6k Main engine rpm limit: 6200
Lean cut: 14:1 Rich cut: 10:1 Closed loop while NOS active: 12:1
4 degrees initial timing retard increasing to 5.4 degrees by 10sec (10sec max NOS duration)
45lbh fuel enrichment
