Brian Bearor
Having an issue with my engine temp gauge. It is slowly showing temp but close to pegging. Temp is no more than 185-195 using a Lazer thermometer.
Replaced the temp sender twice.
Replaced the guage with a new, old stock gauge and same issue.
Cleaned the connections on the plug block as well.
Assuming it is one of the wires.
Before I started changing I thought I would ask the experts if it may be something that isn't obvious before I start down this path.
Thank you for all suggestions.View attachment 1715771273
