dodgegtdart68
When I put the bushing on the front the bushing doesn't give squish down enough to even show the hole that goes thru it. Is it wrong bushing ???
I have read this several times and still can’t understand what your saying.When I put the bushing on the front the bushing doesn't give squish down enough to even show the hole that goes thru it. Is it wrong bushing ???
Also, maybe you have the cupped washer on backwards?
Ok there is no washer on the back side or the lower control arm side plus that is not the correct nut. If the other end has coarse threads your using the wrong strut rods. Those are for 73 and newer. You can use those on the earlier models. But you have to use the bushing for the 73 up struts.
If they are tight no on the spinning. Only one hole for a roll pin on the f
Maybe an optical illusion, but, the front bushing looks too thick to me......and the washer isn't correct. For sure the rear nut and washer are wrong.....well aftermarket anyway....not factory. As SGB mentioned, they didn't use a washer there. The factory nut had a built in one.
The replacement 2 piece bushings use a cupped washer mounted 180 from how the factory mounted theirs. Look at 4spdragtop's post. That's the way they are supposed to look with aftermarket bushings and washers.[/QUOTE
Ya I saw how he did that. That will give me 3/8" more. I was thinking about taking a sawzall to the bushing. Lol
Those look like poly bushings. If that's case, they're notorious for being the incorrect thickness.
Right!Well i posted the thread size and pics that I took with nary a "thanks", but a lot of bitching about your gf. So my comments/pics were removed.
Right!
Get a sense of humor u motorhead needs. Try getting a girlfriend instead of ******* ur tailpipe.Well i posted the thread size and pics that I took with nary a "thanks", but a lot of bitching about your gf. So my comments/pics were removed.
