T&D Rocker fitment
gzig5
Mequon, WI
Can anyone tell what these rockers fit? The guy that has them isn't sure what they go to, but thinks they are for a Mopar. They aren't offset, so not BBM. the stands would indicate W-something race heads but not with inline rockers? Maybe for Magnums? Hoping to get more info from the guy but may not be able to get much.
The TD and Jesel are set up that way.
There for standard heads (X, J, 308, Edelbrock etc…)
with the shaft pedestals removed.
W-2-5 heads have offset rockers.
Magnum heads use Chevy type rockers.
Inaccurate-I had a set identical on my 2011 EMC 371 Magnum head build--The only difference is the "bedplate" Those are probably just for an LA with rocker shaft saddles machined to a certain height is my guess. J.Rob
I was hoping this would be the case. I don't mind milling the stands on a set of heads in order to fit high quality rockers.
