just as many buses i have drivenMy 2020 2500 Limited Ram cam with 2 Alternators?
It definitely wont work without trying it.Exactly....a 2nd alternator for redundancy?
Simple... throw it in the trunk...
Some.thoughts are best to be kept just that....thoughts.
Magnetos create current by capturing mechanical energy from the rotation of the engine which will provide enough energy to spark the plugs, no other source of energy needed. if one mag craps out you switch to the other one. A preflight check on them is to bring the engine to X rpm, to check mag A effeciency, then switch to Mag B to check it.Just out of curiosity- dual mags? I understand you can’t walk home so redundancies- but why mags? No belt to break or will the alternator freeze up in those temps? I’ve never owned an airplane so trying to understand.
Thanks!
Syleng1
$$$$$Use this and just add an alternator instead of an ac compressor
CVF RACING
LOL, I was expecting another WTF !!
Magnetos create current by capturing mechanical energy from the rotating
Same concept with 2 alternators
Unless performance is not the goal. OP wants "to make the engine more symmetrical, more pleasing to the eyes.." You gonna knock him for painting it olive drab too?You cannot make something that is round.....more round.
It takes power [ not much, but some ] to drive the alt. So if you are spending money to improve engine performance, & then take away performance with an unnecessary alt, then it does not make much sense...
My main priority is a spare alt
Think redundancy
It would be great if I could also get more
Benefits from dual alts
My thinking is like a "swiss army knife" , multi-purpose ,Let's not kid ourselves here. When I hear the story start changing...."I'm going for an aircraft theme", "I want symmetry", and "My main priority is a spare alt", you're kidding yourself.
Is your motivation to get back in the cockpit of that Cessna? I banged a hot chick once, I'm not gluing implants and a pocket p***y on my car EVER. Do I want to go back to those days? Yes, but that ain't going to take me there.
Symmetry? You do know that the entire driveline of these cars is off-center, right? The distributor isn't centered either. Thank God you aren't driving a slant 6 car. Symmetry doesn't apply, and never will. You want symmetry? Close the hood and admire how symmetrical it is. Don't get inside the car. Ever.
The benefits of dual alts? Have you had a history of alternator failures? Are alternators somehow unreliable to you? Can you show us where the alternator touched you when mommy wasn't looking? If you think you need a spare alternator, toss one in the trunk with some wrenches and a spare 318, just in case.
But three stories smells like BS and that's what these guys are trying to tell you.
You miss your Cessna, you are searching for perfection and are setting yourself up for failure, and you have a fear of alternator failure but understand the concept of diodes and are still afraid to make a roadside alternator repair. That'll be $60 for the psychology session.
As I noted earlier, his "Cessna" only has ONE alternator on it.You miss your Cessna,
Thanks!!
I personally lean toward this philosophy.
If I want to try to figure something out, there's a 2019 Too-Yota Rav4 in the family fleet that I still haven't figured out what all the unnecessary crap on it does, nor do I even want to
Keep it simple ? Imagine zero computers worldwide !I personally lean toward this philosophy.
If I want to try to figure something out, there's a 2019 Too-Yota Rav4 in the family fleet that I still haven't figured out what all the unnecessary crap on it does, nor do I even want to!
Who do you know that wouldnt be very happy that the item they bought didnt provide not just one purpose, but 24 purposes and would fit in their pocket.
Its obvious that you are not a creative or an out if the box thinker. You called BS on me, which is a classic case of the pot calling
the kettle black.
, BTW, Im currently building a aircraft style
Dash with 24 gauges, numerous dials switches, LED, potentiometers etc.
