Is this splash shield needed?
halfafish
Damn those rabbits, and their holes!
SW Washington
I have this splash shield on the slant in my truck (82 D150). Hooks to the oil pump and shields the distributor, I'm guessing, from splashes?
Is it a good idea, bad idea, or no idea at all? I'm wondering if I should reinstall it.
Absolutely yes. Keeps water off the distributor cap.
Okey Doke. And thanks. It takes up a fair bit of real estate but if I need clearance I can always remove it for a bit.
missing on my belve and never had a issue , but will be putting it on from a a spare engine I have
Where I live, with the amount of water I get, I can see it being a real issue. Mine has a broken tab, and just bought one off another member here, and giong to also fix the one I have using the good one as a template.
