[SOLD] OEM Clutch and Fan
blewbyoutobad
Missouri City, TX
This came with a 340 Dart. Not sure if it is correct or what else it might fit. Clutch is tight. Needs blasted on rear side. - $20
Spacer, I can measure for you. - $5 (Buy fan spacer free)
+frt, PayPal preferred, Houston Area
Thanks FABO
Anyone know what the 3 pin wiring harness fits?
Thanks FABO
Can you measure the diameter of the fan? It’s measured from the midpoint of an arc drawn between two blade tips to the tip of the blade 180 degrees out.
