Daniel Dugas
Hey guys, quick question. I have a carter thermoquad I just picked up. I am trying to figure out details like the CFM of it. The number is 9377s. If anyone has any details I would greatly appreciate it!! Thanks!!
Just googled it.Hey guys, quick question. I have a carter thermoquad I just picked up. I am trying to figure out details like the CFM of it. The number is 9377s. If anyone has any details I would greatly appreciate it!! Thanks!!
Thank you!!A Carter Thermo-Quad Guide (carbkitsource.com)
Everything you need to know about TQs and more...
That could be. I had someone read it off to me. That would make sense.Not on my list either. Could it be 9371? 318 auto.
It’s number was 9377s(or something close). The similar numbers were all mopar carbsIf the number is 93XX, it is not aftermarket.
The big 850 cfm has 1.5" pri bores; the smaller 800 cfm has 1.375"pri bores. So easy to tell which size.
There were some Ford 429/460s I believe that used the TQ; also IH used them on trucks. I had a IH carb here recently; the fuel inlet was in the centre rear of the carb. Mopar carbs have the fuel inlet, rear, pass side.
Thank you!!Nope Not a aftermarket unless 98xx number.
Never 93xx number
They all Look Big.
All 93 numbers are late emission carbs
ThanksMeasure the throttle bore and that will tell you the size. After that you can change the calibration to what an early performance carb came with.
