[FOR SALE] *** SUNDAY GARAGE CLEANING ***
4fortyDemon
St George, Utah
In the process of cleaning stuff out for another cross country move.
Shipping from 19607 . Prefer local pickup but will do my best to pack stuff to ship. Not opposed to package deal.
Located near Reading Pennsylvania
Schumacher 6 cylinder to Big blocks mounts $120 like new but was painted over.
Cross over metal lines for small bolt disc brakes $10 set as seen.
4 hole carb spacer $15
A LOT of 8 3/4 axle seals $25 for all.
4spd or auto trans tailshaft long seal $15
Big block oil pan gasket $10
Reverse light on dash with nut and wire $10
Reusable Holley bowl gaskets $15 for all.
Holley bowl screw gaskets $5
Carter strip kit- used some jets out of it$ 20
Holley bowl adapter $5
MSD wires for big block used but good condition with cap. $30
New in box - cap with good but used Standard blue point rotor $15
if i missed anything in the pics.. im sure i did, hit me up. View attachment 1715967012
Pending already:
oil pan gasket
Reverse light
8 3/4 seals
tailshaft seal
Holley bowl and screw gaskets
Radio delete plate
crossover tubes
I would be interested in the motor mounts,4 hole spacer,strip kit and big block plug wires. Need cost to 49055. Pm me with cost.
I’ll take the radio plate if it is left after the feeding frenzy!
I'll take the 4 hole carb spacer and hardware. is it a 1 inch spacer? Thanks
Dibs on the K-H caliper crossover tubes.
Your inbox is full. Please shoot me a PM when you can. I can see you're busy.
Thanks.
