pishta
I know I'm right....
My '12 Caravan compressor clutch is not engaging. I've got 110 psi in the A/C low side with motor off, I have 14V to the clutch harness (measuring red to 12+ and black to harness leads) and even motor off I have 7.57V (up from 0V after about 40 seconds of turning motor off and pulling the key) to clutch harness measuring its ground to battery +. What gives? Just a bad clutch? no engagement. Im not sure if this is always on (I had harness voltage with AC on and off) and the blend door handles the temperature? Any quick DMM reading on a good clutch, ie continuity on the 2 wires off the clutch coil?
