True that. I remember the first time some one asked me for a Spitznagel about 30 years ago. I had never heard of that tool or brand before.Spot welder dent puller will make quick work of that.
I tried this on a 1970 B-body and got no place really fast. It was so tuff it wouldn’t budge at all. Had to remover it at the pinchwelds and replace the outer rocker.I welded a nail onto my rocker and used it to pull on. Start at each edge and pull it out slowly. Do not start in the center!
H&S Autoshot. Uni-Clamp Multiple Welding Stud PullerHey Mike I need me one of those snatch blocks...that's some real deal HD equip...
LMAO. It works for airing up tires!Take the body plug out of the end of rocker , spray some ether in there and light it ….
LOL. … NO DONT DO THAT !
Until it pops off the rim and blows through your face. I know a guy.Yeah but rubber creates less shrapnel .
Wouldn't be too bad to cut the pinch weld and hammer and dolly the OP's back out. His just had a push on it. Doesn't looked creasedI tried this on a 1970 B-body and got no place really fast. It was so tuff it wouldn’t budge at all. Had to remover it at the pinchwelds and replace the outer rocker.
interesting that it works on the A bodies.
Those things were always gimmicky to me. Lot of ways to skin a cat.The pros weld a line of pins and pull with a attaching block. Pull, heat, and tap.
