Radiator..??
nodemon
St.Louis
I have a 318 4spd Demon... I need a radiator. Whar are my options..best options without any modification needed.
If your frugal like me Champion . There are better ones out there like Be Cool. I've had good results with mine.
What size though... I think stock is a 16 or 18"..?
Did the 340 cars have a bigger rad...? If so, can that be installed without mods .?
Copper / brass and as OEM in style as possible
If an option exists, go for HD cooling / AC option.
22x17 is stock. VERY late years might have had a 26x17 but don't quote me on that.
The BB rads had larger inlets and outlets and MIGHT have been 3 core.
(Someone can confirm that)
383 GTS and Formula S had 22x17 and cool just fine.
$316 to my door from Speed Cooling. I am very happy with it. Fit is very good.
Application is 1973 Plymouth Duster 340/ 4-spd.
Contact: [email protected]
22″ Mopar SMALL BLOCK HD Aluminum Radiator
Contact US Radiator.
They can set you up with the correct radiator for your setup, with the propper core.
Griffin gets my vote. I don't even turn the fans on 90% of the time on a 600+ hp street dart.
