hotrod swinger
Does it matter if the fluid shows half an inch above the full line? No leaks present, no other issues.
Yes I am following the proper procedure.Are you checking it with the engine warn and running and in neutral?
It depends on how you check the level. Check it warm (operating temp) on a level surface, in neutral. Block the wheels so it doesn't roll away. You don't suction any out until you have properly checked the level.I do believe that too full can cause aeration of the fluid.
Get a small dia hose and syphion out some fluid
Thanks "Captain Obvious"You don't suction any out until you have properly checked the level
