[Found!] 273 2 barrel air cleaner base
66fs
Greenwood, South Carolina
Base like the bottom left in the borrowed picture. Base or lid (bottom right) and base. Thanks
The lid is the same as used with a 1bbl baseplate on some '61-'69 Slant-6s, with or without the crankcase breather nipple, so at least there's that. But yeah, the 2bbl baseplate is the prize find, used only in Barracudas to provide an unsilenced air cleaner assembly. Non-Barracuda 273-2bbls '64-'69 got the kind shown by Magnum Valiant, with horizontal (old-fashioned clamp band) fastening in '64-'65 and vertical (wingnut and bail) fastening from '66 on.
you can just cut a regular 72 or what ever 318 2 brl base and use it with the 273 2 and 4 brl lid
Found the top, I’ll have to dig through the garage to see if I can come across the bottom. If I find it I’ll let you know and I’ll measure the opening.
Here’s the top and base. Slight pitting on the base outer edge, everything else looks like surface rust. @66fs
